Results 1 to 7 of 7
    Colorado
    Walk in freezer door closer problem
    On a combination walk in cooler/freezer the freezer door panel that door closer is attached to flexes out about ¼” when opening the door. This causes the closure not to reset every time. I considered just bolting the panel/closer through the through the door with nylon or ss bolts but thought condensation could be a problem. Any advice?
    Thanks MK
    MK
    Southold, NY
    Bolt through
    Jan 2010
    Sea to Sky
    Fill the holes with food grade silicone, then stick the bolts through.
    Sent from my SM-G965W using Tapatalk
  4. Likes Metalman0880 liked this post
  5. #4
    Oct 2016
    Clearwater, Florida
    Use SS bolts for sure, then silicone the hole and stick the bolt through, seal it on both sides. you should be good.
  6. #5
    Colorado
    Thanks for the replies. Bolt through it is. MK
    MK
  7. #6
    Dec 2014
    Quote Originally Posted by mk View Post
    Use Nylon bolts. (Low thermal conductivity)
    SS or all thread will likely sweat and/or ice.
    Sent from my SM-G950U using Tapatalk
  8. #7
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by icy78 View Post
    Or be creative. Use the stainless bolts and add an anti-sweat heater.
  9. Likes icy78 liked this post
