Results 1 to 13 of 13
    Oct 2005
    Oregon
    Something didn't seem right......
    The customer just bought the house six months prior and told me that the previous owner had nothing but problems with the heatpump from day one. Technicians would come out and remove refrigerant every winter and add refrigerant every summer. I went inside and checked the 20x20x1 filter inside the filter grill located in the hallway. When I opened the filter grill the filter just fell out. I went into the attic and disconnected the KD return duct to find this........
    The previous owner ran this system for 12 years like this. I wouldn't doubt it if they sold the house because their heating and A/C didn't work.
    "Pea-Corn and Pop-Nuts"
    Feb 2018
    Bay Area, Ca
    Wow. Just wow. Great find. So simple yet you look like einstein compared to the previous people.
    Sent from my SM-N960U using Tapatalk
    Virginia
    Whats the problem ..... you've never seen duct insulated on the inside before ??
    Virginia
    6 inch insulation .... that bad boy will never sweat
    Nov 2011
    East Side
    pissed off installer maybe?
    Oct 2005
    Oregon
    I'll tell you what, the service call couldn't have gone any smoother. I am not saying that I am some kind of super tech or anything but I listened to what the customer was telling me about the history of the system and checked the basic vital signs. One of the things I have been noticing more and more lately when I show up to a service call is that there are no holes in the supply and return plenum where temperatures have been taken. You can always get your Delta T from the return grill and a supply register but taking your readings right before and after the FAU can give you a more accurate measurement. Sometimes I see where the tech before took the time to seal the holes used to take the readings but most of the time they are left open. The one thing I almost never see on service calls are holes made in the plenums large enough to take static pressure readings. Static pressure readings are as simple to take as taking temperature reading and can tell you a lot about why the system is not working properly. Case in point.....
    This customers system is around twenty years old, the original system from when the house was built. The customer said that the system was working great and always has. My static pressure readings indicated a problem. Cut into the exposed return plenum in the garage and discovered that the return plenum used the space between the upstairs and downstairs as a duct and then shot straight up through a chase to the upstairs where the return air filter grill was installed.
    Ok. That was supposed to be a short response, HaHa
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by napoleon-dynomite View Post
    What did You do to correct that problem Napoleon?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
    Oct 2005
    Oregon
    Those two pieces of insulation pulled right out and problem solved. One of the reasons this customer called our company in the first place was that the previous company told him that the system needed to be replaced. I would have a hard time telling a customer this without first taking all the necessary reading to properly diagnose the system. One of the most satisfying parts of being a service tech is figuring out why things aren't working as they should. Unfortunately there are calls that still have me wondering what the hell happened.........Like this call. The fire dept. was called out and the neighbors reported that it sounded like a bomb went off.......
    I've posted these photos before. The accumulator failed violently.
    Athens, Ohio
    Rust never sleeps. Or so someone said.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Mar 2015
    Hamersville, Ohio
    "Violently" is putting it mildly.
    Jul 2019
    wow. some people
    Sent from my BND-L34 using Tapatalk
    Austin, Texas
    That picture from napolean-dynomite looks a lot like this one.
    Yes - those are the return ducts that "should" be connected to the that filter grill.
    If "I have always done it this way" is a good reason to do it again, how many times do I have to do something wrong - before it becomes right?
    you have one filter that will filter the incoming air the other air does not need to be filtered kidding
