Results 14 to 26 of 49
    Southeastern Pa
    By the way....there are a couple of companies now making plastic inserts to use between the mating surfaces of a flares, because it has become so common for Mini Splits to have leaking flare joints.
    I think one of them is called Flare Seal.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    Rectorseal makes one called Flaretite.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2018
    Wisconsin
    Aug 2014
    Quote Originally Posted by timebuilder View Post
    they sell the flare inserts online,I never used them before, in my opinion i dont like flare connections. If I can braze i would braze & never worry about it leaking,thank you for your recommendation.
    Sent from my SM-G950U using Tapatalk
    Aug 2014
    Aug 2014
    Was that your company's installer?
    no,the job was done by someone else years ago,for me to find the leak my plan is to close the service valves at the condensing unit, & isolate the 3 zones & then pressure to 500psi with nitro, to determine which circuit is losing the pressure & then proceed with repair.
    Aug 2008
    Hibbing, MN
    Quote Originally Posted by nytech28 View Post
    Just had one exactly like this. We isolated the bad circuit and disconnected it from the system. The homeowner did not want to tear into the walls. At least they are up and running on two heads.
    Oct 2016
    Clearwater, Florida
    Sounds like a good idea, though 500 PSI might be a little much unless it's for 410A
    Oct 2006
    The Beach
    You might not want to go up to 500 psi. i never go higher then 300 psi. Good luck. There are times it takes a while to find the leak.
    Blue Fox
    Southold, NY
    the flare connections are inside the walls, to check for leak & the customer not ready to cut walls yet, easy seal would be next option.
    Then it was installed wrong!
    Southold, NY
    Quote Originally Posted by lentz View Post
    On 410A systems they want up too 600PSIG!
  12. Likes JeffWil liked this post.
  13. #25
    Oct 2016
    Clearwater, Florida
    Sheesh, that's crazy.
    Imagine the compressor shooting a pin at you at 600 PSI, go right through you I imagine.
  14. #26
    Aug 2014
    it's a 410A fujistu unit.
