Results 1 to 11 of 11
    Dec 2003
    Citrus County, Florida
    manufacturer's capacity amount
    If the label on a condenser states 4.8 lbs, that means 4 lbs 12.8 oz right? That does not mean 4 lbs 8 oz, right? This is why I like it when Goodman states 177 oz
    Doug
    Sep 2018
    Summerville SC
    That is correct , but not the proper full charge level for the split system.
    I think that is allowing for a 15’ line set , anything over that is an additional said oz per foot . How long is the line set?
    Dec 2003
    Just used that as an example. Tx
    Doug
    Mar 2018
    Chico, Ca #StateofJefferson
    It always seemed like a giant FU from the factory. "Here you go mr. tech, we used a measurement of weight divisible by 16 and wrote it down as a divisible of 10 for you, good luck sucka!
    Southold, NY
    and who’s going to know a 4 Oz difference?
    Feb 2019
    Maricopa, Arizona
    I find it best to charge to factory weight and then adjust superheat/subcool as needed.
    Southold, NY
    Quote Originally Posted by HVAC_wanna_be View Post
    Exactly!
    Sep 2018
    Summerville SC
    Is Goodman using any TXVs on their residential equipment yet?
    Used to be all pistons. As stated setting superheat for pistons, subcool for txv and then recording the full charge is the proper way.
    Feb 2019
    Maricopa, Arizona
    Yes, I've actually came across a few of them.
    Jul 2019
    North Carolina
    4.8 is not the same as 4 & 8 and yes;
    .8 multiplied by 16oz gives you 12.8oz
    Basic math. I think you only asked this so that you could talk up Goodman. BTW system charge on a Goodman is always incorrect because everyone has leaks from the factory.
    Dec 2003
    Quote Originally Posted by sea-sparrow View Post
    I did not ask this to "talk up Goodman".
    Doug
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
