Results 1 to 7 of 7
    Jun 2017
    Ct
    RTAA expansion valve upgrade kit
    Have an electronic expansion valve on a Trane RTAA170 leaking pretty bad. My local supplier said I need to do an upgrade kit and change out both expansion valves as well as controller? Has anyone done this before? Thanks
    in a tree looking in your window
    been done many times, pretty straight forward
    If you dont stand behind our troops, please feel free...........to stand in front of them.
    Jun 2017
    Ct
    Thanks for the info. How long would you say it will take to change out the two valves and a controller? I’ve never done it so I’m just trying to give an idea to the suits at my company.
    Oct 2005
    Quote Originally Posted by Dave122290 View Post
    I did a chiller over a weekend. 1 day to recover, install, leak check and evacuate. Next day to re-charge and check operation.
    RTFM!!!
    Apr 2017
    The Deep South
    Quote Originally Posted by manny238 View Post
    Good advice above. I've done them several times in one long day. That sucks, but sometimes you don't have a choice with a process machine.
  6. Likes manny238 liked this post.
  7. #6
    The Hot South
    Why did you recover the gas?
  8. #7
    Oct 2005
    Quote Originally Posted by R123 View Post
    Process chiller they only shut down 2 times a year. circuit #1 had a low charge we took out charge to confirm and go back with nameplate. circuit #2 had small leaks that needed to be repaired on condenser coil.
    RTFM!!!
