Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Sep 2018
    Summerville SC
    Not flaking just eroding ,
    so it doesn’t effect production or heat exchange etc???
  2. #28
    Oct 2016
    Clearwater, Florida
    IT affects harvesting to the point where some ice may be left behind, when it gets really bad, the ice can tend to stick to the evaporator. That also happens if any of the cross links on the evaporator are loose.
    Normally they flake, without seeing it, it's hard to say but if you are seeing a reduced production of ice, perhaps the culprit is the evaporator.
  3. #29
    Where the grass is green and the girls are pretty
    That was tin and it affects production. Those run the water pump in harvest and the longer the ice is stuck there the more the ice gets melted away.
  4. #30
    Aug 2019
    I would not recommend that....plating evaporators is a very technical process. I would change the evaporator for many reasons. Or replace the machine
    Tim Parsons
  5. #31
    Jul 2012
    Seen them work with no plating. Just make sure it's smooth, stays clean and you didn't hear it from me lol
    And make it lean forward a lot !!! Lol
  6. #32
    Jun 2018
    Bay saint louis ms
    Quote Originally Posted by captaincompressor View Post
    That machine is bad about losing the batch water too
  7. #33
    Oct 2009
    Raleigh, NC
    Quote Originally Posted by Dacman View Post
    I don’t work on many ice machines so here’s a question for y’all if you don’t mind.
    An older Scotsman machine at a site of mine has a good deal of pitting and erosion on the nickel plated sheets.
    What is the end result of it pitting out and not a perfect finish??
    Seems like the older it gets the less ice it makes.
    Water cooled condenser, charge weighed in and flow rate set to proper head pressure on condenser .
    Seems like it stays in harvest longer than it used to before dropping ice.
    Just curious.
    I have never seen an older Scotsman CME plate look new for more than a month or two of service. They quickly look stained and pitted and bare, but they usually keep on working. There are still quite a few in regular service in my area.
    Sent from my Pixel 2 using Tapatalk
