Results 14 to 26 of 33
    Jan 2010
    Quote Originally Posted by 2sac View Post
    Where the grass is green and the girls are pretty
    Oct 2011
    Chicagoland Area
    Great movie
    Jul 2000
    Guayaquil, EC
    I suppose you could remove it and drop it off at a nickel plating co.
    But aren't some plates integral with the molded plastic ?
    The Scotsman CM/CME evaporators are like that.
    As for replating, I have only seen it done one time about 25 years ago on a Manitowoc G-series, back when their evaporators were failing so bad they (quietly) extended the warranty to 8 years. Soebody had taken the evaporator to a local plating shop to get it re-nickeled. It was a total fail in opinion. The coverage was good and thick, but it had bumps, runs and what appeared to be foreign material in the nickel. I figured they weren't big on the finer points of plating. The finished reminded me of when my father took a couple dozen 2˝ gal ice cream tubs and covers to a shop for re-plating. Probably a quick acid dip & rinse and then straight to the plating tank.
    Anyway, the re-plated evaporator worked as poorly as a flaking one...except it was shiny.
    Oct 2016
    Clearwater, Florida
    I had a similar problem, I tried thinking of something and just replaced the whole unit.
    Most cases the evap is so expensive it's not worth replacing just the evap so I Replace the whole thing and end up gutting it and keeping the compressor,sensors,fan motors and whatever else is still good.
    Jun 2018
    Bay saint louis ms
    Just changed one today the plastic ear was broke off Q model Many 1500 $ but I work for the gov No one wants to spend that kind of money except the Gov. if it was my call I would have glued it back on easy to change but extremely expensive !
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by Mars65 View Post
    FYI...Manitowoc has a Top Molding Kit available:
    Jan 2010
    Quote Originally Posted by icemeister View Post
    Didn't know that, thanks ice .
    Sep 2018
    Summerville SC
    I don’t work on many ice machines so here’s a question for y’all if you don’t mind.
    An older Scotsman machine at a site of mine has a good deal of pitting and erosion on the nickel plated sheets.
    What is the end result of it pitting out and not a perfect finish??
    Seems like the older it gets the less ice it makes.
    Water cooled condenser, charge weighed in and flow rate set to proper head pressure on condenser .
    Seems like it stays in harvest longer than it used to before dropping ice.
    Just curious.
    Jan 2010
    Quote Originally Posted by Dacman View Post
    Just curious.
    Old enough to be a mechanically timed harvest or electronic ?
    Old enough to be tin plated not nickel plated
    Sep 2018
    Summerville SC
    I’m not sure on the tin or nickel plating, but the harvest is viewed by photo eyes in the drop area. Just curious what degrading plates would affect.
    Jan 2010
    Quality of the ice I.e. metallic flakes in ice.
