Please note the bright red banner at the top of the page. We cannot assist in DIY instruction here.
Frozen lines out to AC unit. Turned off unit let everything thaw out then started troubleshooting. Blower motor won't turn on at all -- just hear humming when I enable unit from thermostat. Tried giving blades a spin by hand to startup with no luck. Would like to test capacitor but not visible in lower cabinet.
Any ideas?
TIA.
“I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
“It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
R I P Icemeister
Supporting our Vet’s
http://www.soldierride.org/
http://www.woundedwarriorproject.org/
Thanks for replies. Wasn't really looking for a how-to just a "where is it at", apologies if that is in violation.
Unit hasn't been serviced for a few years so plan on calling contractor shortly. Wanted to understand issue a bit more before calling as I don't really have any I trust (not that they aren't out there, just don't have established relationship with one).
There is a contractor locator map here on the site that includes the volunteers here.
Maybe see if someone is in your area that can help.
Thanks. Will do.
“Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
"It's what you learn after you know it all that counts." ~ John Wooden
"When the teachers become unteachable we're all in trouble" ~ Mr. Bill
"Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
Isn't that kind of like getting on an auto repair forum and asking where the oxygen sensor is because you have a oxygen sensor fault and you want to be able to show your mechanic where it is so he can change it?
I mean, why would you ask where the capacitor is located , if you weren't intending to look at it and change it?
Sent from my SM-G950U using Tapatalk
Primarily because I wanted to understand what we had going on so I can ask correct questions given i have no established relationship with a HVAC company. If it was a $10 fix I may have done it myself but either way I was calling someone out to check the entire system because it has been several years and I have no way of checking for leaks, etc. Same thing I do with my cars. If I'm paying for a pro I want to get as much as possible out of it.
Apologies if i offended, money was still gonna flow to a professional.
FWIW tech just left and the blower & module were bad. Instead of the repair I agreed to replace both furnace and ac and he provided us with a temporary fix until they can get out and do the work (supposed to be 99 here next few days). The info I found from the internet and forums helped me have an educated discussion with the tech about the issues I am seeing and feel much more comfortable agreeing to replace the entire system. We covered several topics that I would not have been able to otherwise. He did give me a repair option but it was more money than i was willing to spend on a 15 year old system.
Also no capacitor on this blower.
