I used to work on a burlesque / movie theater that had been built in the 1920's. Built into the outside wall of the mechanical room penthouse was a massive thick water coil - maybe 10' by 20'. I eventually found that down next to a 2+ million BTU furnace (for the radiant floor heating system - all red brick air ducts - was a big vertical water pump with a 4" discharge. It pumped from a well they said was 300' deep and supplied water to the huge water coil.
When I was a kid I had puzzled over why the alley behind the theater was trough-shaped. As an adult I found that it was the original drain path for the "air conditioning system'. <g>
That 100% outside air though a well water coil was - so far as I could find out - the original cooling system for the theater.
Just inside that big water coil was a series of big evaporators piped to three open drive Carrier compressors - R-12. I often wondered if those compressors has Always been there - and the water coil only serves to pre-chill the 100% outside air intake.
Smoking was allowed then so I imagine a theater needed a huge fresh air flow and prechilling it with well water would have made sense. But no one alive knew anything that far back.
PHM
Quote Originally Posted by numbawunfela View Post
I worked for TETCO before they got bought by their current owners. They are apparently the original Geothermal HVAC company from the early 70s.
They marketed an A series cooling unit that was nothing more than a water coil that just pumped and dumped well water for cooling. Sat on the furnace like an A coil would.
Only slightly less hoaky than a crane radiator....
