Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Jun 2013
    Toronto, Ontario
    Not sure what they were going for
    Or for what purpose
    Jun 2013
    Toronto, Ontario
    Then there’s this one kinda following the same theme: why?
    Quote Originally Posted by Stevejoe11 View Post
    The thermostat photo should be common practice.
    Plug the hole so any air movement in/out of that hole does not influence the temp of the stat.
  4. Likes Lahrs liked this post.
  5. #4
    Aug 2015
    Buffalo,NY
    The first picture? Is that just combustion air being dropped Into a basement? I wonder why so much?
  6. #5
    Sep 2015
    Ontari-ari-ari-o
    Quote Originally Posted by Metalman0880 View Post
    That was my first thought too but usually the combustion air pipes are stuffed with old rags to keep the cold air out and carbon monoxide in. Probably a planned run for an HRV for a new subdivision home that the low bid installers never bothered to finish.
  7. Likes Lahrs liked this post.
  8. #6
    Virginia
    Could they lead to a crawl space where pipes can freeze ?
  9. #7
    Nov 2008
    Long Island NY
    What's up with the electric baseboard too?
    Sent from my SM-G965U using Tapatalk
  10. #8
    May 2014
    Bay Area California
    Looks like they're trying to get heat to a room upstairs.
    Quote Originally Posted by Jettinvr6sc View Post
    I do a triple evac with nitro to remove non condensables.
  11. #9
    Nov 2008
    Long Island NY
    Quote Originally Posted by BBeerme View Post
    Make you wonder what they were thinking. Maybe to heat the crawl space in the winter time.
  12. #10
    Jun 2013
    Toronto, Ontario
    Quote Originally Posted by pacnw View Post
    I couldn’t care less if there’s some air in an inside wall that’s like maybe 1/2 a degree difference touching the thermostat, not like a basic stat is really THAT accurate anyway. Maybe if I was installing in a lab or something.
    And yes those are baseboards stacked on top of each other installed underneath, they are wired up. The flex lines terminate in a row on outside wall with exhaust grills
  13. #11
    Oct 2014
    Saint Pail, Minnesota
    It’s basically big deal when there is an unconditioned space above or below. It allows unconditioned to give false readings. Hold a flame up to the hole sometime and watch it dance in the draft
  14. #12
    Well I'm sorry you don't care, but those of us that do have no issue with photo 1.
  15. #13
    Quote Originally Posted by Pnasty View Post
    Commercial job where conduit runs up into the plenum ceiling or, as stated, an unconditioned space can be a big deal.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
