Results 1 to 1 of 1
Thread: Water Furnace Geothermal Purge Pump Cart
    Jan 2019
    Water Furnace ground source purge pump cart with Vari-Flow reversing valve rated 75 gallon per minute
    Allows water flow in loop to be reversed without removing hoses during flushing operation.
    Mounted on two wheel cart with supply and return hoses and quick connect fittings.
    120 Volt Motor with supply tank on cart
    Flush cart is the professional's choice to purge air and flush debris from residential and light commercial
    geothermal ground loops.
    listing will be removed when item has sold
    cash only $1300
