Results 1 to 13 of 27
    Apr 2013
    Heat pump for air conditioning
    guys - I have a non-efficient central AC system powering up my 2200sq feet home. 2 zones covering basement, 1st and 2nd floors. I've started research on a heat pump with the intention to keep the home AC on 24x7 during the summer months of June-Aug. I don't mind the initial investment which I understand could be $$ but wanted to ping this forum to see what my running power costs could be. I know a heat pump is very efficient but guess I'll still need an air handler/blower
    Can someone guide me on this - I live in a very high power cost city - NYC and it's about 42c/kWh here. Rough approximations would do for now and this home is a old 100 year old non-insulated home (indoor and outdoor stucco)
    Thx
    Apr 2013
    I’m wondering if geothermal heat pumps installed vertically can be done in new york
    Southold, NY
    Quote Originally Posted by betterair View Post
    Only if the building has a cooling tower!
    Southold, NY
    guys - I have a non-efficient central AC system powering up my 2200sq feet home. 2 zones covering basement, 1st and 2nd floors. I've started research on a heat pump with the intention to keep the home AC on 24x7 during the summer months of June-Aug. I don't mind the initial investment which I understand could be 20k but wanted to ping this forum to see what my running power costs could be. I know a heat pump is very efficient but guess I'll still need an air handler/blower
    Thx
    How has the size been determined?
    Single unit serving multiple floors rarely work out as expected!
    Jun 2014
    Dover, DE
    A heat pump isn’t a part you install, it’s a matched complete system.
    As for efficiency, it will only be as efficient as to how well it’s installed, and how well the building envelope is sealed.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
    Apr 2013
    what's my best bet for a building that's not well sealed. Should I go for air source heat pumps instead and what manufacturers should I start with. I plan to call their dealers and get a local consultation
    thx
    Jun 2014
    Dover, DE
    Hire the installer. Not the brand.
    The hands working on the equipment, means a lot more then brand name.
    Brand means almost nothing.
    Local 486
  8. Likes Vinnie_NJ liked this post
  9. #8
    Southold, NY
    Is there a cooling tower in the building?
    Are you allowed to tap into it?
  10. #9
    Apr 2013
    this is a 100 year old private house. Should I do a blower test to check the envelope's insulation?
  11. #10
    Southold, NY
    A blower door test checks the homes leakage. Air changes per hour so you know where improvements can be made.
  12. #11
    SW FL
    A LOT OF JUICE ... N E C E S S A R Y
    guys -
    Thx
    ___ THINK HARD..!...!!
    about building YOUR Own POWER PLANT.
    __________________________ ~70K dollars for maybe 20 KW SOLAR PV
    Designer Dan
  13. #12
    SW FL
    HEAT LOSS might be in THE _BALL PARK of 64,000 BTU/HR at 15'F
    Your Heat Loss approximation from link
    ___ THANKS to GARY.
    ___ Attachment
    ___ www.loadcalc.net
    ___ ___ ___ LOAD CALC 2200 SQ FT BUILT 1918 2 STORY With Basement …
    Designer Dan
  14. #13
    Apr 2013
    wow that graph is super helpful. I didn't know my heating costs will go way up with high efficiency systems.
    My main goal with high efficiency was with my current system, it just doesn't feel comfortable - either too cold or too warm as it constantly cycles on and off. Any solutions to that?
