Results 1 to 13 of 13
    Jul 2019
    Evacuating a flooded evaporator on a chiller barrel
    Hello all, first post here. I知 working on a Smardt(dumb) chiller with a flooded evap. This unit has two compressors with 2 chiller barrels that have the same water lines heading to all the air handlers. We had to recover all the freon out of one circuit to fix a freon leak, and left the other operating. I知 to the point now of pulling a vacuum, as nitro held at 145psi for four days. My question is with cold water still going thru this evacuated barrel, is there any chance of moisture building up inside. Thanks all
    New Jersey
    If there wasn't any moisture in the system you will be fine.
    Sent from my ASUS_P00J using Tapatalk
    ottawa canada
    Whats “Freon” ??
    Nov 2011
    East Side
    Water has to be in the refrigerant side to begin with.
    145 psi for 4 days isn稚 really a helpful test. Trace gas with pressure test close to low side factory test, and leak check with electronic and soap would tell you more.
    Apr 2016
    Maryland
    I would triple evacuate - breaking with nitrogen - to 1000K micons or less . I am not happy until I achieve 1000K or less . There is a site I work that has thier people witness a 24HR vacuum test before I place refrigerant into the repaired area . I am OK with that - LIABILITY and doubt non existent . I have repaired MANY YORK YTs and YKs along with Carrier 17FAs
    Quote Originally Posted by CHILLERSVCMAN View Post
    I would triple evacuate - breaking with nitrogen - to 1000K micons or less . I am not happy until I achieve 1000K or less...
    1000K? Isn稚 that 1 million microns?
    "Right" is not the same as "Wise".
    Apr 2016
    Maryland
    ONE thousand
    Jan 2013
    United Kingdom
    1k is a 1000
  9. Likes brett2008 liked this post.
  10. #9
    Jul 2009
    New Orleans
    Cold water running through a heat exchanger with one side open the atmosphere could lead to quite a bit of water build. If the system was open just long enough to make a simple leak repair you should be ok. 145psi for 4 days is a good indication that your system is tight but 1000 microns for an hour would be better to prove the integrity of the system. You probably wouldn't get to 1K if you had any significant water in the system.
  11. #10
    Apr 2012
    So.Fl. & NYC
    Hi Guys, yes a triple evacuation would be the order of the day. I致e had refrigerant leaks pull through to the evacuated portion of an evaporator before. From a running system on a dual evaporator. So evacuate and pressurize and do a quick leak check.
  12. #11
    Nov 2019
    Hi
    What type for metering does flooded evap use?
  13. #12
    Jul 2009
    New Orleans
    Flooded Metering
    Quote Originally Posted by Sako93 View Post
    Hi
    It can be fixed orifice, variable orifice, float assembly, metering plate or expansion valve. Essentially anything that you can think of.
  14. #13
    Nov 2014
    Australia
    Triple evac - less than 500 microns - good standing test - like 24hrs (is possible).
