Page 4 of 4 FirstFirst 1234
Results 40 to 45 of 45
  1. #40
    Jun 2006
    Dual pressure switch. There is no dual pressure valve.
    And, no.
  2. #41
    Jul 2019
    Quote Originally Posted by stat View Post
    And, no.
    Ok then what next????
  3. #42
    Jun 2006
    An experienced tech will diagnose this in no time.
    It is not possible to trouble shoot something if you do not understand how it works.
    Even if we are able to pin point the issue, most likely you will not have the resources to make the repair.
  4. #43
    Southold, NY
    Is this what you have?
  5. #44
    Jul 2019
    I got the correct model and serial number....
    Model....CPB075DCO-A
    Serial 08051399
  6. #45
    Southold, NY
    Quote Originally Posted by bklnci View Post
    Serial 08051399
    https://www.partstown.com/modelManua...EF-SYS_iom.pdf
