Results 1 to 12 of 12
    Jun 2019
    Is this my TXV and was it replaced a year ago
    I've had a HVAC company out several times because my AC isn't working adequately. About 1-2 years ago they stated the TXV needed to be replaced and replaced it. Since then, they've been out several times and after a little screwing around it starts to work beautifully. When the technician was supposedly replacing the TXV, he dripped water all inside my furnace, ruining my inducer fan and control board, which I had to replace myself. I wonder if he didn't just give up as he was having difficulty and cussing left and right. As the summer progresses, it stops working adequately and i have to call them again and again and again. It IS NOT losing freon or undercharged. My question is this: Are the attached pictures my TXV and was this really replaced? It looks old as hell. Thank you.
    Feb 2014
    Fontana, Ca
    That's your TXV.
    Was it replaced? There's no way of telling consider finding a reputable HVAC recommendation from one of you're buddys.
    Sent from my Moto Z (2) using Tapatalk
    Moved to AOP.
    By the burn marks, and the sloppy brazing, it looks like it was replaced.
  4. Likes lions_lair liked this post.
  5. #4
    Mar 2018
    Chico, Ca #StateofJefferson
    I hope that kind of brazing doesnt fly at the factory
  6. #5
    Jun 2019
    Why would it be in such poor condition? Could they have replaced it with a used part?
  7. #6
    Dec 2003
    Citrus County, Florida
    That is ugly.
    Doug
  8. #7
    Houston,Texas
    Quote Originally Posted by Makeitcold View Post
    I hope that kind of brazing doesn't fly at the factory
    That's not factory?
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "Skilled Labor Isn't Cheap, Cheap Labor Isn't Skilled" ~ Unknown
    "When the teachers become unteachable we're all in trouble"
    "It's what you learn after you know it all that counts." ~ John Wooden
  9. #8
    Southeastern Pa
    The appearance also depends upon the conditions it's been exposed to during the past year.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #9
    Jun 2019
    The copper line was replaced at the same time the TXV >supposedly< was. That would explain the burn marks.
  11. #10
    Oct 2009
    God's country - Shenandoah Valley, VA
    The valve should have been disassembled while brazing. It looks like the hack didn't do that. He probably cooked it to the point that it's sticking which would explain why your cooling functions intermittently.
    Bob Boan
    ​You can choose to do what you want, but you cannot choose the consequences.
  12. #11
    Mar 2018
    Looks like either it’s been in a salt water environment or the power head got so hot it cooked the paint right off!
  13. #12
    Southold, NY
    I just replaced a valve from 2002 that didn’t look that bad!
