Results 1 to 13 of 20
Thread: Inficon Stratus
    Oct 2009
    Atlanta,Ga.
    Inficon Stratus
    anyone used the new Inficon Stratus leak detector?
    Central NJ Area
    I just picked my stratus up today. I have only used it for 10 minutes on a known leak. My initial impressions of the stratus to this point have been very impressed. It is capable of very high sensitivity level and cloud mode with PPM read out on the display. I did not have any false alarms from tapping the tip against objects after it has warmed up a few minutes. I will report back soon after putting the stratus to work in the field on some upcoming leaks search work.
    Issues.
    I don’t like the usb charging port due to the fact they tend to get damaged. The battery latching mechanism has let loose twice and is difficult to reset the battery I into the holder. I have to contact Inficon. This is the first production of a new model...
    Oct 2009
    Atlanta,Ga.
    do you think it is better than the H10 pro.I have a DTek select now,Debating on getting the H10 pro or the new Stratus
    Central NJ Area
    Quote Originally Posted by Gleng View Post
    I need to spend sometime with it. The H10 pro is always good to have.
    Jun 2013
    Northeast Wi
    Have you had a chance to use it on 410a yet?
    Oct 2009
    Atlanta,Ga.
    I bought one today.I have not used it yet.I will post how I like it.It opted to buy the Status over the H10 pro.
    Mar 2009
    Triad - North Carolina
    Who has them and for how much.
    Yes, I've seen that before and it doesn't mean I like it.
    Oct 2009
    Atlanta,Ga.
    I bought mine at United refrigeration.$930.00,including tax.(not cheap)!!!!
    Mar 2009
    I'll be waiting on that one. Too rich for my blood.
    Oct 2009
    Atlanta,Ga.
    i knew it was coming out a few months ago, so I saved up for it.I have an envelope i call my tool saving money.I usually save up for expensive stuff .
    Central NJ Area
    Quote Originally Posted by Keith73 View Post
    $895 Johnstone Supply. I'm hoping to use on a leaking Mitsubishi multi city mini-split leak search today
    Oct 2009
    Atlanta,Ga.
    Im hoping it's worth the money!!!Time will tell.
    Central NJ Area
    I'm a electronic refrigerant leak detector junkie. I'm currently carry the SRL8, tek-mate, Testo 316-4, H10 Pro and Stratus. I also have the Tif ZX (damn batteries), Bacharach tru-pointe IR, Dtek Select, older H10 120v and a few others. I mainly search for R410a leaks. The company has only been installing R410a systems since 1994. When carrier released the 38TXA Puron condensing units.
    I've been searching a long time for the best electronic detector (mostly R410a), but I have found that different models work better at locating different types refrigerant and jobs. NathanHVAC, A forum member, did a review on a bunch of models and compared their sensitivity to R22 & R410A. It's probably the most extensive unbiased test I've come across. It wasn't done with lab type precision but was still quite informative.
    I have high hopes for the stratus. I usually wait for tool reviews from forum members, but I had to try this new leak detector myself. I pre-ordered the stratus and received a small discount rather then waiting for its release. I've had good luck with Inficon leak detectors in the past. I hope this wasn't a poor purchase destined for Ebay!
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
