+ Reply to Thread
Thread: Hozy moisture sensor?
    Jun 2018
    Bay saint louis ms
    Confused Hozy moisture sensor?
    Does a Hozy have a wet switch?I took my pump out and loaned it to a customer until his pump came in from the supply house . When I put my pump back in my machine and turned it to ice making I noticed. no beep no start either I said to myself look at this s”””” . So I got curious and I filled sump with a garden hose low and behold it beeped and came back on line ! KM600 is the model
    Jul 2000
    Guayaquil, EC
    When switched to "Ice" there will be a 5 second delay, then the water valve will open. After a "1 Minute Fill Cycle" the board checks the float switch to see if it's closed yet. If still open, it'll do another fill cycle, etc. Basically, nothing else will happen until the sump fills.
    See p.35: http://icemeister.net/files/icemaker...ide%20Book.pdf
    Jun 2018
    Bay saint louis ms
    The machine was in the. Ice position with water pressure on it I had no light on circuit board as soon as I put garden hose in the sump and started to force fill it the machine cranked up it was in the ice position for at least ten minutes and would not do a thing until it saw water . I seen stranger things with ice machines . I had to do this to Manys more than once,!(add water to them until the water probe gets wet I guess it rests the computer or something to that nature.you have to unplug Scotsmans to get them thinking right
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by Mars65 View Post
    It sounds like there was no power to the board when you first switched it on. It could be a sticky bin thermostat or mechanical bin switch if it has that instead.
    Anyway...to answer your question, no it doesn't have a moisture sensor. The closest thing to that would be the float switch.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
