+ Reply to Thread
Results 1 to 2 of 2
Thread: ERV AS POST FIRE SMOKE PURGE SYSTEM
    Mar 2019
    Hi, I am working on a commercial 16 story building in Manhattan and it is using an energy recovery wheel. The ERV in normal operation is supplying air to the space. There is no exhaust tied to the return. It is just a return duct on each floor with a FSD. There is another smoke purge operation where post fire it is able to purge the smoke at the required rate. Is it a good idea to use an ERV for a smoke purge system?
    Madison, WI/Cape Coral, FL
    Imagine smoke exhausting out through an ERV wheel. Fresh air passing through the smoke coated webs of the ERV wheel?
    Regards Teddy Bear
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
