Results 1 to 17 of 17
Thread: Bev Air cap tube issues
    East Haven,CT
    We have a customer that has multiple stores that use their sandwich prep tables and all of them have gotten plug cap tubes within 2-3 years. Condensing coil’s are kept clean any reason why this is happening on different units?
    Southold, NY
    Quote Originally Posted by nickpt828 View Post
    Plugged caps are a result of POE + R-134A + HEAT. You need all 3. Coils clean but how hot is the kit?
    East Haven,CT
    Not that hot. Newer kitchens with A/c, the ambient around them is probably 75. They pull the air in the back but I’ve told them to keep them a few inches off the wall but don’t listen.
    East Haven,CT
    They are all SPE60s by the way.
    Southold, NY
    There you go!
    East Haven,CT
    I’m going to get rubber bumpers and screw them into the back wall. You’d think they’d put in the owners manual saying not to push against a wall.
    At The Point Of No Return
    Last couple of years BA quality went from bad to worse. Hate to say it but I think some MIC crap is better now.
  8. Likes UmmScott liked this post.
  9. #8
    Aug 2013
    Omaha
    Those SPE prep tables are HORRIBLE to work on.
    Bring your drill.. you will need it to extract the hundreds of screws and dismantle all the ducting/prep top just to see the evaporator.
    And yeah...they like to plug cap tubes as well.
    Seen the condenser coils lately? Really tiny, no fan shroud, high condensing temps, etc..
    I wouldn't sell one of these to my worst enemy LOL
    Sent from my SM-G975U using Tapatalk
  10. #9
    Jul 2000
    Guayaquil, EC
    I believe you need a little moisture too.
  11. #10
    East Haven,CT
    I just had another one with plugged cap tube, coil was clean, and was kept 8” from wall. I beginning to think they’re just junk.
  12. Likes UmmScott liked this post.
  13. #11
    Jul 2000
    Guayaquil, EC
    I can't disagree about the junk part, but when one considers all of the similar style units out there, they all tend to have the same compressor manufacturers, using the same refrigerants and oils yet a few brands seem to have an abnormal amount of cap tube failures. For years my suspicion has been this could only be attributed to quality control issues in of the original component assembly process...ie, having to do with proper system cleanliness, nitro purging, evacuation, etc.
  14. Likes Juan Madera liked this post.
  15. #12
    East Haven,CT
    Beverage aire is only manufacturer having issues with at these units but the other coolers they use like Silver King are using R404a.
  16. #13
    Oct 2009
    Raleigh, NC
    Are you sure the cap tubes are restricted and you don't just have leaking evaps?
    Sent from my Pixel 2 using Tapatalk
  17. #14
    East Haven,CT
    Yep. Critical charge systems I always recover, evacuate and weigh in correct charge.
  18. #15
    Southold, NY
    Dont know if you saw this.
    https://hvac-talk.com/vbb/showthread...-cooler-issues
    There looking for someone to fix it
  19. #16
    East Haven,CT
    Thanks but no thanks. I’m on shoreline plus I can pretty much “diagnose” them, probably paying a side job hack to fix their equipment cheaply got them into this problem.
  20. #17
    Aug 2009
    Maine
    Quote Originally Posted by MicahWes View Post
    A bit of moisture in the system will plug a cap tube for a while. (:-
