Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    Jun 2010
    Houston, Texas
    Carrier 6 Ton RTU High Suction Pressure
    R22, 6 ton light commercial straight cooling RTU, 1 month nearly new Danfoss scroll compressor, previous tech also converting the original fixed orifice to TXV two weeks ago, cleaned evaporator and condenser coil, blower and OD fan motor in normal operation. 80F outdoor dry bulb, condenser fan rejecting air temp 95F. AC return air 75F, supply air temp 65F at register outlet, discharge pressure 215 psi, discharge temp 229.8F, suction pressure 101psi, with 4F superheat 6 inch before compressor. 21F subcool. compressor is running at higher than normal temp. Now come to the question, will a faulty TXV cause high suction pressure due to stuck open like 90%? no matter how to adjust the superheat, nothing happen to the low side pressure. need some advise here, thanks.
    Virginia
    Did the tech add any more freeezon than label says ?
    Im really confused how the discharge is 226 F , if the txv is wide open sending back really cold gas ...
    Make sure they didnt send you a bigger compressor
    NH
    Sounds like a bad compressor to be. With a flooding txv u will have high discharge and low superheat. Could try slowing down the blower or running it with no blower to see if suction pressure is still really high.
    Southeastern Pa
    Part of what I'm wondering is was the TXV conversion done properly...
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2018
    Quote Originally Posted by jumstar View Post
    21F subcool.
    I’d start here...
    Virginia
    Hold up
    Theres some story we arent hearing
    New compressor 1 month ago
    TXV swap 2 weeks ago ....
    Whats the whole story
  7. Likes jumstar liked this post
  8. #7
    Jun 2010
    Houston, Texas
    I doubt that too, but hard to tell
  9. #8
    Jun 2010
    Houston, Texas
    I attempt to remove nearly 1 lb of r22, same condition exists, right size compressor
  10. #9
    Jun 2010
    Houston, Texas
    Will try to run without blower when I get back this morning
  11. #10
    Jan 2010
  12. #11
    Southeastern Pa
    Typically we also like the model and serial number for the unit in question and the label information from the new compressor might also be helpful along with information about the TXV itself.... from its label.
    Which refrigerant is the original refrigerant for the unit from the manufacturer, and is a different refrigerant being used now?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #12
    Nov 2011
    East Side
    22* discharge SH is low for a scroll compressor.
    Recover charge and weigh.
    Sounds like the conversion is the culprit. The new distribution header should have an orifice, sized for the tonnage. Also the distribution tube size, and number of tubes Needs to be sized for the correct pressure drop. Got any pics of the conversion?
  14. #13
    Jun 2010
    Houston, Texas
    Quote Originally Posted by timebuilder View Post
    Using the original R22
