    Jun 2019
    PXC36, Apogee and USB
    Is it possible to connect to the controller via USB instead of the RS-485 with Apogee? Siemens support does not make it easy to find the info or configure if it is an option. I'm looking for a more robust connection as we are an OEM and I'm connecting to these controllers on a regular basis to upload our database. A reinforced metal USB connection would be faster, easier and last a lot longer. Links to drivers or instructions on configuration would be greatly appreciated.
    Disclosure: not an HVAC-R tech or engineer, just a self taught electrician.
    Thanks in advance
    Jun 2019
    EDIT: currently using Ethernet port to upload our database with a fixed IP address via apogee. not the RS-485 port.
    May 2002
    Baton Rouge, Louisiana
    You can connect to the USB but only to set some controller settings, you can't upload a database by USB.
    Quote Originally Posted by MatrixTransform View Post
    very soon it is you that will be pwned
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
