Results 14 to 26 of 33
    Mar 2013
    Treasure coast, FL
    Quote Originally Posted by GoCougs View Post
    I use a “kerf saw” with very fine teeth. At first it didn’t seem like the best tool for the job, but after trying various smooth blade knifes unsuccessfully, I gravitated back towards the saw.
    How many teeth per inch is that one? I just found a 42 TPI version that looks like it's the same brand as the one you pictured.
    Sent from my Moto Z (2) using Tapatalk
    Nov 2014
    Northern Idaho
    Quote Originally Posted by shellkamp View Post
    Yep I believe its 42
    Mar 2013
    Treasure coast, FL
    Awesome. Just ordered it, thanks.
  4. Likes GoCougs liked this post
  5. #17
    May 2014
    Bay Area California
    Whoa, didn't expect to see what I saw in the OP.
    How much time did it take to do just what is in the photo?
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  6. #18
    Nov 2014
    Northern Idaho
    Insulating ref piping
    Quote Originally Posted by BBeerme View Post
    Takes probably 3 minutes or so to make the fitting, so for a trap that 9 minutes, then another couple to properly glue them together, and another couple to fit of the pipe and glue the seam. So the trap and the tee was probably 15-20 minutes. Certainly not the quickest way.
  7. #19
    May 2014
    Bay Area California
    I've always tried to do the best I could when insulating. It does take dedication and attention to make it decent.
    And you sir, have done very well. Just the lack of glue showing is a skill in and of itself !!
  8. Likes GoCougs liked this post
  9. #20
    Oct 2005
    B.C. Canada
    I like how you piped in that tee.. after the trap, yet still fully functional.. I probably would have tried to tie in before the trap somehow, only complicating things.. good job! True fridge mechanic work!
  10. #21
    Nov 2014
    Northern Idaho
    Quote Originally Posted by coolerik View Post
    I must admit, I did not do the refrig piping. The piping is 20+ years old, I was just fixing the insulation that was leaking onto the box
  11. #22
    Oct 2005
    B.C. Canada
    Old guys knew how to pipe it correctly.. it’s a lost art! Obviously being 20yo there is no oil return problems.. probably still running the original compressor
  12. #23
    Dec 2012
    columbus, OH
    Thats craftsmanship, dont know where I heard it but, I did hear there are no small jobs only small people. Ive often taken that to heart and into practice but now I feel so ashamed of all the armaflex ive butchered to date...
  13. #24
    Dec 2009
    maroon lazyboy
    A link for a kerf saw.
    Zona 35-550 Fine Razor Saw, 42 TPI.010-Inch Kerf, Blade Length 6-1/2-Inch, Cut Depth 1-3/16-Inch https://www.amazon.com/dp/B000BRESQY..._EdYbDb8WMRY4G
  14. #25
    Jan 2010
    I use scissors or my tin snips never tried a kerf saw. Will give that a go next time.
  15. #26
    Mar 2018
    Maryland
    I bought the lineset tape a few weeks ago. It’s horrible! If you really have to tape it use the thick 1-1/2” electrical tape from capitol Tristate or put a small amount of arms flex glue on the back of foam tape. That works waaaaayyyy better
