Results 1 to 13 of 33
    Nov 2014
    Northern Idaho
    Insulating ref piping
    For some weird reason I enjoy insulating haha. Nothing special but I really appreciate how much better mitered fittings work rather than just sliding it over, where it can pinch and ice up on freezer suction lines. I didnt do the liquid line, I was just fixing the suction.
    Apr 2003
    Maple Grove, MN
    That is a thing of beauty! That is definitely the right way to do it, but few people have the patience (or a sharp enough knife) to accomplish anything close to being that nice.
    If I were to try something like that I would probably end up with glue all over myself and it would end up looking like an abortion.
  3. Likes Rustytool liked this post.
  4. #3
    Oct 2005
    B.C. Canada
    What kind of knife do you use? It blows my mind how quickly cutting armaflex dulls standard razor knife blades..
  5. Likes BALloyd liked this post.
  6. #4
    Nov 2014
    Northern Idaho
    I use a “kerf saw” with very fine teeth. At first it didn’t seem like the best tool for the job, but after trying various smooth blade knifes unsuccessfully, I gravitated back towards the saw.
  7. #5
    Oct 2011
    Chicagoland Area
    Very nice. You'd of gone thru 2 packages of razor blades to make all those cuts
  8. Likes GoCougs, BALloyd liked this post.
  9. #6
    Oct 2011
    Gladstone, Oregon (Portland)
    Just split it and use a good lineset tape and tape it completely.
  10. #7
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by Adlerberts-Protege View Post
    What's lineset tape? OK, I just looked it up. I've been looking for something like this for several years, I never knew it existed. I have been using black duct tape, but that stuff sucks. I'm going to get me some real lineset tape now. Thanks AP.
    Note... I'm not saying this lineset tape could in any way be a replacement for the method that GoCougs uses, but I can see where the tape could have it's place.
    If at First You Don't Succeed, Skydiving Is Not for You.
  11. #8
    Dec 2009
    maroon lazyboy
    On freezer suction lines, it is not good to have much tape on the outside of the insulation, the insulation can’t breathe properly and can become waterlogged and drip during defrost.
  12. #9
    Oct 2005
    B.C. Canada
    How does closed cell insulation “breath”?
  13. #10
    Dec 2009
    maroon lazyboy
    Quote Originally Posted by coolerik View Post
    Good question. It’s what I was taught, and frost is an issue on lines with too much tape. But there is a strong possibility that I am wrong as well!
  14. #11
    Oct 2005
    B.C. Canada
    I doubt it’s about breathing, mabey the tape is on to tight squishing the insulation and ruining its R value.. or just not thick enough?
  15. #12
    Nov 2014
    Northern Idaho
    Thats a big emotional negatory for me
    The stuff I tore off had a combination or poor glueing techniques and black duct tape over that. Once water gets between the insulation and the pipe its going downhill from there. The armaflex manual says that if you want you can put a wrap of tape around the joints after theyve been properly glued. Theres no way taping it will make the airtight seal you need.
    Armacell even recommends glueing the insulation to the pipe at intervals, so that if a section gets infiltrated it doesn’t ruin everything.
    Tape might be a great solution for resi AC but no way in commercial refrigeration.
  16. Likes Jettinvr6sc liked this post.
  17. #13
    Jul 2012
    WA
    That is some seriously impressive insulation work!
  18. Likes GoCougs liked this post.
