    May 2013
    Generic replacement condenser motors
    Found this on a RTU with 2 condenser fan motors. This one slowly spinning away, directional wiring shorting out on the fan blade. Bearings were completely shot, worst I've seen. I wonder if the intermittent ground fault going through them caused the excessive wear?
    I hate this style of replacement motor! Should never be used as a first choice.
  2. Likes CEAS-AC-TECH liked this post
  3. #2
    Oct 2011
    Chicagoland Area
    That motor looks like it's been there awhile. Choose a ball bearing motor over a sleeve bearing and don't forget to pull out the drain plug, and secure the wiring, and it should last a real long time.
  4. Likes CEAS-AC-TECH, Lahrs liked this post
  5. #3
    Jul 2016
    Tahoe
    That there is what I call a high-powered-wire-stripper, and a pretty piss poor install.
  6. Likes Lahrs liked this post
  7. #4
    Urbandale IA. USA
    It was NOT PROPERLY installed.
    I would not have left the threaded part of the mounting bolts that far above the nuts.
    I would have preferred to have some 'washers' between the nuts and the mounting plate.
    I personally would have applied some turbine oil on those threads also.
    It delays rusting.
    The wires should have had a sleeve or should have been TAPED together and SECURED properly.
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
  8. Likes Lahrs liked this post
  9. #5
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by 2sac View Post
    Indeed 2sac, ... But maybe they liked that soothing "Ching!Ching!Ching!" noise of the wires hitting the blades.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  10. #6
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by washer View Post
