Results 1 to 11 of 11
    Jul 2009
    Columbia, MD
    Mitsubishi for a garage
    Put this in for my buddy in his garage. Should cool him down and heat him up when he’s playing with his toys.
    ask your buddy if that dayton heater fan starts up slow and runs slow for a bit then goes to full speed when its first turned on for the season or is off for a while i have the exact same unit in one of my property's and wanted to know thanks
    the install looks good
    Jul 2009
    Columbia, MD
    Will do. He’s got 2 in there and they are off at the breaker for the summer. He probably will never use them again now that i put in that unit
    Thanks i would advise him to set the heat pump whare he wants it and set the daytons 10 degrees under that so they kick in in case the heat pump cant keep up ie after the door is open for a car to go in or out etc never hurts to have back up
    Jul 2018
    This looks great! Does this system have a condensate pump?
    Jul 2009
    Columbia, MD
    Quote Originally Posted by unreg0x1 View Post
    No pump
    Jul 2018
    Quote Originally Posted by gravity View Post
    No pump
    Does the drain run through the line hide?
    Jul 2009
    Columbia, MD
    Yes
    Aug 2001
    Pavilion, NY
    Looks mint! The only thing i would nit pick about would be that the disconnect does not meet clearances (30" unobstructed width and 36" in front)
    'The more you know, the more you realize you don't know'
    May 2018
    FLORIDA
    Here in Florida, almost every "rich people house" have a ductless / mini split in the garage
    Apr 2005
    Australia : Queensland
    What Kw is that 7-8?
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
