Results 1 to 9 of 9
    Nov 2015
    Carrier Infinity Thermostat - Occupancy Sensor sucks
    It is not really sensitive is it? It keeps switching to AWAY when there is someone in the house.
    This is a problem in summer when it shuts off the AC when it thinks some one is AWAY but actually is not.
    Should have a microphone or something.
    I have disabled it when I know someone i going to be home for the day. But it's a hassle.
    Anyone else have better luck with it?
    Currently for summer, I have it set at 78 for Wake, Home and Sleep, and 80 for Away, so the temps don't get to much out of control while someone is still in the house.
    There is little comfort in this feature when it can't tell if someone is home or not.
    It is also very slow to react when you are moving just a few feet in front of it.
    Good feature, but very poor implementation!!
    Southold, NY
    Not a good idea to have large swings in temperature with a heat pump. Basically set it and forget it!
    Nov 2015
    Yeah but we got expensive electricity here and 2 degrees is not a big swing.
    Southold, NY
    Quote Originally Posted by elefantrider View Post
    and virtually no savings!
    Jun 2014
    Dover, DE
    That’s likely enough to trigger backup heat in the winter, depending on what deadband is.
    Which will quickly raise your electric bill.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Local 486
    Jul 2005
    The Infinity t-stat does not have an occupancy sensor.
    Quote Originally Posted by hvacrmedic View Post
    Yes, the newest touchscreen does.
    I disable them and don't inform the customer. They are "free" to discover it on their own. It's not that difficult to disable/enable.
    there was/is another poster that reported the same issue with maintaining program settings. The sensor was disabled and I think the problem has been resolved.
    Jul 2000
    Northern Wisconsin
    The occupancy sensor should only be enabled when the space it controls is all one large area that all areas are visible by the sensor. It's like a lot of other "bells and whistles" on high end digital thermostats these days, each option needs to be evaluated if it fits your situation or not and if it doesn't then it should be disabled.
    In your case, have the occupancy sensor disabled and just use the programmable feature.
    Jul 2005
    Good to know. Thanks.
