Results 1 to 13 of 19
Thread: PTAC argument
    Aug 2012
    PTAC argument
    I am considering a PTAC unit instead of having current HVAC system fitted (re-done) for central air.
    Now, I have a small home - 850 SQ FT. with a crawl meaning my furnace is a down draft. This means a little more difficulty in design and refurbish than normal.
    And, since I am renovating it would be easy to frame in to an exterior wall.
    The other bonus would be that a PTAC is self-contained only needing power pulled to it.
    The PTAC cost for a 1 Ton unit is actually cheaper by far than all the components and cost of retrofitting the original (newer and efficiant) HVAC.
    These are the (Pro's) of this idea, what would be the (Con's)? Looking for good experienced advise or thoughts.
    Jul 2011
    DFW, TX.
    Not enough air circulation and humidity issues are in the ptacs future...
    Sent from my LG-G710 using Tapatalk
    Jun 2014
    Dover, DE
    The problem is conventional PTAC equipment is very localized as far as what it can do.
    Although ducted PTAC units are made. Very popular in dorms around here.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Local 486
    Aug 2012
    Well, the bigger challenge with retro-fitting is the A-coil would have to mounted under the furnace (down-draft). The condensation drain would be at the floor level and become a problem to mitigate as the crawl is difficult.
    Suggestions?
  5. Likes CEAS-AC-TECH liked this post
  6. #5
    Jul 2011
    DFW, TX.
    Not hard. Its done common in mobile homes.
  7. #6
    Oct 2009
    God's country - Shenandoah Valley, VA
    Your letting your cheap gene cloud your judgement. A PTAC is not gonna properly heat and cool your home; it's gonna have a short life expectancy; it would have to be done away with if you try to sell the house; and it's gonna be objectionably noisey.
    Do you really wanna put up with a cheap motel unit?
    Bob Boan
    ​You can choose to do what you want, but you cannot choose the consequences.
  8. Likes CEAS-AC-TECH liked this post
  9. #7
    Jun 2014
    Dover, DE
    Quote Originally Posted by delamite View Post
    Suggestions?
    Not difficult at all. Put the coil as high as possible and use a condensate pump.
    Easy.
    Local 486
  10. Likes CEAS-AC-TECH liked this post
  11. #8
    Jul 2011
    DFW, TX.
    Even most hotels are doing away with the ptacs. What does that say? Id take a ducted mini split over a ptac... Just saying.
  12. #9
    Aug 2012
    OK, OK ..
    A-coil being biggest obstacle, I suppose it has to be mounted underneath furnace and not possible to mount traditional on-top?
    That would make retrofitting much easier if possible.
  13. #10
    Jun 2014
    Dover, DE
    If you have a furnace, that’s a good way to rot your heat exchanger quickly.
    Local 486
  14. Likes CEAS-AC-TECH liked this post
  15. #11
    Aug 2012
    I get it.
    Thx everyone will have this job done correctly. I just like to know thing and be prepared before hiring contractors.
  16. #12
    Athens, Ohio
    OK, OK ..
    It is only traditional in an up-flow configuration. It is completely wrong to do so for a down-flow.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  17. #13
    Southold, NY
    Get a ducted Mini and enjoy it!
  18. Likes CEAS-AC-TECH liked this post
