Results 1 to 4 of 4
Thread: oil return thought
    in a house, Appomattox, Va.
    oil return thought
    was thinking about units on roof at apartment buildings. manufacturer says may not need oil traps, but...
    if the units are oversized, say a 2 ton for 800 sq ft apt, most of the time they're not going to run long. how long do you think a unit would have to run to push oil back up several floors? or am I overthinking it?
    Col 3:23
    Depends on suction line size.
    Southold, NY
    Quote Originally Posted by billygoat22 View Post
    Check out
    Dupont’s Best Piping Pratices!
    May 2014
    Bay Area California
    Yeah, depends on the velocity of the refrigerant, how well the apartments are insulated, and the total length of run.
    You've posted this in a residential forum, but if the apartment building is multi story, I would call that commercial. For example, not too often you see a five story or higher residence.
