Results 1 to 4 of 4
    Jun 2012
    Lynchburg, VA
    Help in Identifying a Rheem Packaged Unit
    Unfortunately the data tags are faded out and there aren't any other tags inside the unit (that I have been able to find). Can anyone identify this unit based on the attached images on PDF? The unit is a heat pump - I'm guessing in the 5-7 ton range. Thank you in advance.
    Southold, NY
    So there’s No Compressor Tag?
    Aug 2013
    Visalia California 93291
    RRGG Series, get the compressor info
    Jun 2012
    Lynchburg, VA
    Thank you for your response. It's not a gas-fired unit, but the series number looks like it will get me headed in the right direction!
