Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 56
Thread: My Home
  1. #40
    Aug 2011
    Canada eh
    I will say its good but not perfect! Why is the HRV hard mounted? Usually comes with springs for the unit to be hung-no issue with vibration transferring the noise. Also why did you make a transition to the coil box? They are designed to site directly on the furnace
  2. #41
    Mar 2014
    Grand Blanc
    Quote Originally Posted by twinrivers View Post
    Lol..... ok. The ERV that I purchased comes with brackets attached for mounting. There are rubber isolation pads used when attached. I have no vibration or excess noise complaints. I install transitions between my furnace and coil whenever possible. This gives me a great spot for static pressure testing. I find it also lowers the coil pressure drop a little below manufacture data.
  3. #42
    Atlanta GA area
    Yes... one 'can' stack a coil directly on a furnace... however a short transition helps with airflow through the coil as well as keeping the heat from the HXE back from the coil pan.
    There is nothing wrong with placing the coil away from the furnace... Carrier and ICP offer factory transitions.
    GA-HVAC-Tech
  4. #43
    Aug 2015
    Buffalo,NY
    Personally I think this is pure artwork with functionality. Iíd have my living room set up around this. My one question though is, are you not using how water? Or not living there yet? Only reason I ask is because that navien looks like itís unplugged.
    Awesome work!
  5. Likes johoff34 liked this post
  6. #44
    Jul 2011
    N.E. Ohio
    This install is in the Sept. issue of SNIPS magazine.
  7. Likes johoff34 liked this post
  8. #45
    Mar 2014
    Grand Blanc
    Quote Originally Posted by Metalman0880 View Post
    Awesome work!
    Thank you! I put a lot of time and effort into the metal. Yes the house was new construction so water heater was not done at the time of picture. All up and running now.
  9. #46
    Mar 2018
    Maryland
    Thatís awesome man! Iím about to do something similar in my uncles house. Wanna do it w/o canvasís like you did. I know you already said you havenít had any vibration/noise issues. But have you ever had problems w/ hard ducting everything?
  10. #47
    Virginia
    Quote Originally Posted by kdean1 View Post
    Shiny!
    Looks great. I like the elevated furnace to make use of the large air filter. I predict your house will be very comfortable.
    I didnt even notice that .... yea thats bad ass
  11. #48
    Mar 2014
    Grand Blanc
    Quote Originally Posted by Pres1227 View Post
    No. Thereís just less room for error. If youíre making everything on site itís not that big of a deal. I usually make all my fittings before I do the job, so my pre measurements are critical.
  12. #49
    Aug 2009
    Beatrice, NE
    It looks great . . . as always.
    Question, all the ERV's I have installed require insulated duct to the outside, this doesn't need it or will be installed later?
  13. #50
    Mar 2014
    Grand Blanc
    Quote Originally Posted by BNME8EZ View Post
    Thanks! I insulated the ducts connecting to the outside after. I donít like flex unless itís straight runs so I did metal pipe here. Then insulated with R8 after the fact.
  14. #51
    Apr 2004
    MN
    Beautiful work! Changing the residential world one install at a time! Keep up the outstanding work! To those saying that venting needs to be higher, how do you know? Are you familiar with the snow fall totals in Grand Blanc? I'm curious, because I live in Minnesnowta and my vent pipes are about the same distance off the ground and I've never had them buried in snow.
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
  15. #52
    Feb 2014
    Quote Originally Posted by johoff34 View Post
    Having a home built. Finished up the metal today. Installed an ERV, pretty excited for that. Never had one, never installed one. Also picked up a Ultra-Aire 70H to make Teddy Bear happy. I made some videos installing this and making some fittings. Iím gonna figure out how to edit and load to YouTube. Once I figure it out Iíll post a link.
    On the R/A why a change elbow, offset and then a offsetting transiton? You could have had the Elbow, one Transtioning offset and a tap.......
