Results 14 to 26 of 56
Thread: My Home
    Jul 2009
    Columbia, MD
    Too bad it’s not a Trane.
    Everything else looks great.
    Seams up on the rounds. Check
    Mastic. Check
    Taped. Check
    Proper take offs. Check
    Big filter. Check
    Reduced TEL fittings. Check
    Good work my man
  2. Likes johoff34, Brian8383, shavedneon liked this post
  3. #15
    Virginia
    I like how the copper lineset and drain is hidden so well ..... we can barely even see it .....
  4. Likes johoff34 liked this post
  5. #16
    May 2009
    SC
    Interesting on the ERV, you have any monitoring on it? Is it a wheel or just air to air?
    Scott Jalbert, WebCTRL ninja, Naiagara AX and EcoStruxure Building Expert newb, SiteScan Retired
    The master has failed more times than the beginner has even tried
  6. #17
    Mar 2014
    Grand Blanc
    Quote Originally Posted by firecontrol View Post
    Why the sheet metal between the furnace and coil? They look to be the same width.
    Great looking metal work.
    Two reasons. Helps give the air coming off the blower more of a chance to straighten out. I’ve found by installing these on my last few jobs that the static pressure lowers. Second it gives a great spot to put your static pressure probe!
  7. Likes Brian8383, AdrianOmarPerez liked this post
  8. #18
    Mar 2014
    Grand Blanc
    Quote Originally Posted by MaxBurn View Post
    Not sure what you mean by wheel or air to air. It has a blower in it and an energy core. Control by percentage timer.
  9. #19
    Jul 2000
    Northern Wisconsin
    Quote Originally Posted by johoff34 View Post
    Do you have any numbers on the reduction in static pressure?
  10. #20
    Jun 2007
    The Woodlands, Texas
    Very nice
  11. #21
    Aug 2019
    Clean look. Love it. What are you using to control the Ultra-Aire?
  12. #22
    Mar 2014
    Grand Blanc
    Finished Product for now....
    Sent from my iPad using Tapatalk
  13. Likes BALloyd liked this post
  14. #23
    Mar 2014
    Grand Blanc
  15. #24
    Mar 2014
    Grand Blanc
    Ultra Aire 70h is ducted into system, has supply backdraft damper and tee fitting with damper. This allows me to put some dehumidifier air into the basement until I finish it with supply and returns. Also have Renew Aire EV130 installed for fresh air ventilation. Very comfortable so far!
  16. #25
    looks good but the air intake and exhaust would be under the snow in no time where i am from
  17. #26
    Michigan
    Great work!
    It is a carrier however. Not a fan of carrier.
