Page 1 of 5 12345 LastLast
Results 1 to 13 of 56
Thread: My Home
    Mar 2014
    Grand Blanc
    My Home
    Having a home built. Finished up the metal today. Installed an ERV, pretty excited for that. Never had one, never installed one. Also picked up a Ultra-Aire 70H to make Teddy Bear happy. I made some videos installing this and making some fittings. I知 gonna figure out how to edit and load to YouTube. Once I figure it out I値l post a link.
  2. Likes shavedneon, Metalman0880, Core_d, lzenglish liked this post.
  3. #2
    Feb 2011
    Chicagoland
    Beautiful tin work. Look forward to seeing your videos.
  4. #3
    Madison, WI/Cape Coral, FL
    I must compliment you on a trim installation. Also you sure know hour to make a "Teddy Bear" happy and thank you!
    How are you going to connect the Ultra-Aire into the a/c?
    What is your fresh air plan? Climate?
    Keep up the good work!
    Regards Teddy Bear
  5. #4
    Mar 2015
    Hamersville, Ohio
    Quote Originally Posted by johoff34 View Post
    Having a home built. Finished up the metal today. Installed an ERV, pretty excited for that. Never had one, never installed one. Also picked up a Ultra-Aire 70H to make Teddy Bear happy. I made some videos installing this and making some fittings. I’m gonna figure out how to edit and load to YouTube. Once I figure it out I’ll post a link.
    DANG!!! Lookin' Very Good !!!
    Did you find that by using the Engineered Floor joists that running the Duct, Electric, & Plumbing was easier for the Install?
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God痴 law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, 的 wasn稚 sent to anyone but the lost sheep of the house of Israel.
  6. #5
    Jul 2018
    Wisconsin
    It's a beautiful thing. I'm pretty sure you will need some insulation on your ERV
  7. Likes johoff34 liked this post.
  8. #6
    Mar 2014
    Grand Blanc
    Quote Originally Posted by teddy bear View Post
    Regards Teddy Bear
    Thank you Teddy, I enjoy reading all of your comments. Very educational.
    I live in Michigan, green grass climate. I installed an ERV for ventilation. I think eventually I will install the dehum into the duct with a Tee and damper for basement. It痴 undersized for the house and basement. Ideally I just got it for the basement. I have a 5 stage VS Ac going in, I want to see how that handles humidity during low load conditions first. Plus I致e never had an ERV either so I want to see how that helps as well.
    I will keep you posted.
  9. #7
    Impressive!
  10. #8
    Oct 2011
    Gladstone, Oregon (Portland)
    How are the connections to the erv sealed? Yes, had to find something
  11. #9
    Jul 2009
    Columbia, MD
    Very beautiful work. Kudos
  12. Likes johoff34 liked this post.
  13. #10
    Jul 2010
    napping on the couch
    Neat install. Great work.
  14. Likes johoff34 liked this post.
  15. #11
    Jul 2000
    Northern Wisconsin
    Why the sheet metal between the furnace and coil? They look to be the same width.
    Great looking metal work.
  16. #12
    Jul 2009
    Columbia, MD
    Quote Originally Posted by firecontrol View Post
    Better airflow and serviceability
  17. Likes johoff34, Brian8383 liked this post.
  18. #13
    Athens, Ohio
    Shiny!
    Looks great. I like the elevated furnace to make use of the large air filter. I predict your house will be very comfortable.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  19. Likes Brian8383 liked this post.
