Results 1 to 11 of 11
    Jun 2019
    Evolutions thermostat will not hold settings
    We had a whole house system installed in Sept of 2018. (New build) We are currently on our second evolution's thermostat. But had the same issue. Even the installer cannot determine what is wrong.
    We will set up all the profiles. Wake, home, away, sleep; with the correct times and temps that we want. Nothing is overlapping. No matter what temp we set them to, they default to 78 degrees in the summer. It was different temperate in the winter; but, again not the temp that was set.
    Any help would be appreciated.
    What do you mean they default to 78°?
    Every temp setting?
    Is unit supposed to be working but isn't and temp goes to 78°?
    You need to provide more information.
    Maybe post a photo of the screen.
    Jun 2019
    The unit is working fine. It's just the thermostat that seems to do as it pleases.
    This was taken in the morning after it came off sleep setting. As you can see the schedule is set for 74 but when you look at the current temps it says it will only cool to 78.
    Quote Originally Posted by SandyB View Post
    Can you take a full screen shot of the first photo?
    Jun 2019
    Here is a full photo. Name:  IMG_3471.jpg
    Are you sure that all the days are programmed correctly?
    The full screen shot is in the scheduling area and showing only one day. The second photo, in your first set of photos, is showing what that day and period is set for. You could have only one day set as you want it.
    If this photo is how you want it to be set, then copy this to each day. You can do each day individually or in a block of days(M-F),(S-S), etc.
    If they are programmed correctly, there is a hold option to try and even change this to a non programmable stat. These are last resorts to see what may be happening.
    Jun 2019
    They are all programmed the same.
    Not sure what you mean by a hold option. I don't want to take it out of program mode as I do like the away option for when everyone is gone for a few hours. (No need to keep the house as cool, so I really don't want to disable that option.
    I just really want an answer as to why it will not follow the set schedule and defaults to 78. Which is fine when no one is home but a little warm when I'm here.
    Thank you for trying to help me with this issue!
    Mar 2014
    Grand Blanc
    Do you know if the motion sense is enabled? If it is and your thermostat is in a low traffic area like a hallway then it will disregard you schedule to save energy. I think it’s if it doesn’t sense motion for three hours it will go into smart setback.
    Jun 2019
    I didn't know that there was that option. Yes it was on and in a hallway that doesn't always get a lot of traffic. I have disabled it. I will see if that helps.
    Thank you so much for all of your help!
    Quote Originally Posted by johoff34 View Post
    That was in the back of my mind as well.
  11. Likes johoff34 liked this post.
  12. #11
    Jul 2000
    Northern Wisconsin
    [QUOTE=johoff34;25727761]Do you know if the motion sense is enabled? If it is and your thermostat is in a low traffic area like a hallway then it will disregard you schedule to save energy. I think it’s if it doesn’t sense motion for three hours it will go into smart setback.
    Good catch!!
    They're going to keep making things smarter and more efficient until it gets to the point where we will be putting ten dollar snap switch thermostats back on the wall.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
