Results 1 to 12 of 12
    Jul 2009
    Columbia, MD
    Old work Iíve found
    If you do a search, you can find the actual threads i made with more pictures. Critique away
    Jul 2009
    Columbia, MD
    All insulated up. Hired an insulator
    i can do both my self and do i love my work like you do
    only thing i would do differently is run the back wire in its own conduit looks better then the ton of zip ties
    Mar 2013
    Treasure coast, FL
    You're pretty good for an amateur.
    Maybe some intermediate to advanced classes will help you really polish your photography skills.
    Sent from my Moto Z (2) using Tapatalk
    Jul 2009
    Columbia, MD
    Quote Originally Posted by shellkamp View Post
    Rough crowd. I donít know how i feel about this. Im going to go replace a TXV now.
    I don't like the S9 installs. Putting a media cleaner right up against the cabinet means no air goes over a good chunk of it due to the 14x18" opening in the side of the furnace. Our distributor makes a transition, yes it takes room, but 1 side attaches to the furnace and the other side is 16x25 to attach to the air cleaner. That way all 16x25 of the cleaner gets airflow. On bigger units, they have 6" boxes for under the furnace and a different transition that uses the 14x18 plus the size of the riser box to attach to a 20x25 cleaner. My favorite though and would work great on those 2 jobs is putting a Right Angle Air Bear beside the furnace. Attach right to it, the entire 20x25 surface of the media will get good airflow.
    Jul 2009
    Columbia, MD
    I agree. If space permits, i add a transition
    Jul 2009
    Columbia, MD
    I was able to fit one in on the tam9.
    The one furnace with bubble wrap was 16x20 duct and filter.
    The other furnace was 16x25 which got restricted. But I have return coming off the right side that cant be seen
    Oct 2011
    Gladstone, Oregon (Portland)
    In the drop is the best place.
    Jul 2009
    Columbia, MD
    Quote Originally Posted by Adlerberts-Protege View Post
    You talking about the duct drop coming down? Transition there?
    I also agree with that. Proper take offs are important
    May 2019
    Such a good work! Really neat
