Results 1 to 12 of 12
    Oct 2010
    My toaster keeps shocking me
    When I retrieve a bagel with my trusty butter knife I keep getting zapped. Should I do it from outside the bathtub ?
    Jan 2010
    I would resort to plastic ware that should remedy your issue.
    Apr 2004
    Waterloo N.Y.
    Use your finger. Wet it first for a better grip
    Oct 2008
    Quote Originally Posted by mcr View Post
    I was going to say don't feed the troll, but he's banned now anyway.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    Oct 2011
    Chicagoland Area
    Only after he shoves the butter knife up his ass for a proper ground.
    Jan 2010
    Que Sera Sera
    Jun 2019
    don't worry
    Jun 2019
    I was making toast in my toaster over the other day and something odd happened. I set the timer and walked away, when the timer went off, I went to pull out the toast. I noticed the bread was not toasted, so I opened the door of the oven to see if it had warmed up at all. When I touched the bread I received a strong shock, similar to scuffing your socked feet on the carpet and touching something metal.
    May 2014
    Bay Area California
    Were you in the bathtub?
    Quote Originally Posted by jackfowler View Post
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Jun 2006
    I am always shocked when the toast is not burnt...
    Virginia
    Ive read someplace Bread has been known to kill people
    No .... actually it might have said Bread can make people gain weight
    Neither is good for you , leave the Bread alone
    Oct 2008
    Jack Fowler, THANK YOU for all your input in this forum.
    In the CHILLERS OPEN FORUM:
    Carrier AquaEdge 19XR Chillers feature state-of-the-art two-stage compressors optimized with dynamic simulation technologies and intermediate economizer.
    The REFRIGERATION AND ICE MAKING forum:
    Hoshizaki is a global leader in the design, manufacturing, and marketing of equipment for the foodservice industry, including: Ice Machines & Refrigeration.
    The TOOLS & TEST EQUIPMENT forum:
    A flashlight (more often called a torch outside North America) is a portable hand-held electric light. The source of the light is usually an incandescent light bulb (lamp) or light-emitting diode (LED). A typical flashlight consists of the light source mounted in a reflector, a transparent cover (sometimes combined with a lens) to protect the light source and reflector, a battery, and a switch. These are supported and protected by a case.
    The INDOOR AIR QUALITY forum:
    Duct cleaning has never been shown to actually prevent health problems. Neither do studies conclusively demonstrate that particle (e.g., dust) levels in homes increase because of dirty air ducts.
    ...and yet AGAIN, the TOOLS & TEST EQUIPMENT forum:
    A good socket set will help you confidently tackle motoring DIY jobs. We put 10 to the test.
    Sir, you’re a virtual WEALTH of information. THANKS AGAIN!
  13. Likes BALloyd, The Turtleman liked this post
