Results 14 to 18 of 18
    Jul 2009
    Columbia, MD
    I thought you would have figured it out when i quoted your post.
    I also post my work in the WOP. Critique it all you want. I wont get my feelers all worked up.
    Oct 2011
    Gladstone, Oregon (Portland)
    Quote Originally Posted by gravity View Post
    Like most people. You post without listening. Good night to you.
    i like the use of the tape for sealing the joints not a big fan of the gray pookie as i call it but it does work
    Atlanta GA area
    'Pookie' is a code requirement in many areas...
    And in GA (state)... it is required to be 2MM thick (as thick as a nickel coil).
    It does have this one quality... if you smear it all over taped joints... the tape does NOT come loose with age.
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
    Oct 2011
    Quote Originally Posted by pctech View Post
    I used the mastic tape for places I dont want to run into. Try to pookie everything else I can physically get to. This job isnt duct tested for leakage but I do try and do it if at all possible.
