Results 1 to 2 of 2
    May 2019
    Will sulfur containing water harm geothermal heat pump system?
    We have two wells on our property. One is a ground water well that may not provide the necessary volume required for heat transfer. It's a big old brick well 30" x 36' but right now isn't providing even 5 gpm.
    We also have a deeper well that if it still works could probably produce the necessary volume of water to the system but has a lot of sulfur in it. Don't know the ph but could find out before using. Right now I'm just trying to find out if this deeper well would be appropriate for geothermal assuming it produced a sufficient volume of water.
    thanks
    Oklahoma
    Typically heat pump manufactures post a water quality chart that indicates what parameters the water should be in. It would require you to have your water tested though.
