Results 1 to 13 of 21
    Mar 2019
    Ice-o-matic trips GFCI
    I'm a 9 year commercial refrigeration guy and get the call: ice machine is tripping the GFCI. It's an ICEOMATIC ICE0500HA4. I dig into it, and sure enough it trips the GFCI
    . It does this any time the ice curtain opens, whether I did it by hand in the middle of the cycle or at the end when it harvests. I tried a couple different outlets with the same result. I inspected the wiring, looked for shorts to ground, ohm'd everything I could think of. Finally I called ICEOMATIC and tech support says this is a common problem and the outlet shouldn't be GFCI. I'm not buying it. Any ideas? No, I didn't try the machine on a non GFCI outlet. Couldn't find one in the whole restaurant.
    Southold, NY
    Refrigeration doesn’t like GFIC’s.
    Have sparkle change the GFCI somewhere too sensitive.
    Virginia
    Tech support told you Dont use a GFCI .... So if you want the problem to go away , do as advised
    Oct 2011
    Chicagoland Area
    Sparkle? Is that a gender binary term for a sparky?
    Where the grass is green and the girls are pretty
    How high of a resistance can your meter read?
    Mar 2019
    Fluke 116. 6.00 M ohms
    Southeastern Pa
    Well, codes require that all of the kitchen outlets be on GFCI protection. If this unit has its own circuit, you might try placing a GFCI breaker in their panel and then installing a conventional outlet for the ice maker to plug into, and then you can label it as "GFCI protected."
    You could also try replacing the GFCI outlet itself with a different brand. Some are more accurate and less sensitive to false actuation.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Nov 2016
    Ardmore, PA
    I thought that if it was a dedicated single outlet (not duplex) it could be non-GFCI. I'm old and senile but I remember running into this issue with basement sump pumps. They don't like GFCIs either.
    Shouldn't do anything if you open the curtain in freeze on newer machines. Will it trip if you.... Nevermind
    Virginia
    I seen a guy , a few times or so , replace crapFI's with a regular rec and not charge the customer ....
    Changed what ? Hell I dunno what your talkin about ....
    Southeastern Pa
    Quote Originally Posted by jmlandru View Post
    At one time, that was true.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    So if the problem is new and the machine has worked in the past whats changed ?
    Mar 2019
    That's what I'm trying to figure out. It's beyond me that opening a switch will trip it out, and I didn't believe it myself til I tried it 12 times on three different circuits. Amp draw on N was .2A lower than on L1, but it won't trip unless that curtain switch opens.
