Results 1 to 13 of 22
    Aug 2014
    looking nitrogen adaptor
    hello techs am looking for a nitrogen adaptor that connects from nitrogen tank to a 1/4 refrigeration hose ,no regulator in between ,to blowout condensor coils ,the regulator that I have for my nitro tank is restricting pressure which is not enough to blowout coils any recommendation would help ,thanks
    Sent from my SM-G950U using Tapatalk
    Jul 2018
    Wisconsin
    The fitting that goes into the tank is a CGA580. I think the MPT size is possibly 3/8 on the end of that fitting. Then 3/8 couple then 3/8 MPT x 1/4 flare
    Sent from my SM-G960U using Tapatalk
    In a state of confusion
    Hope you never loose your grip on the hose. I cut the nut off a 1/4” hose and it works great for clearing coils through a regulator. The nut and core depressor diverted the flow.
    Jun 2014
    Dover, DE
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486
    Chicago area
    Either get a different reg or try cleaning coils with something else.
    Air compressor, or better yet, a water hose.
    Aug 2014
    Quote Originally Posted by Spitz View Post
    thank you for sharing your info,i will probably get a different regulator
    Aug 2014
    I have exact hose set up,just need a regulator that gives me more pressure, thanks for reading my post
    Aug 2014
    Quote Originally Posted by heatingman View Post
    different regulator will do, thanks buddy
    Aug 2014
    the links you sent helped ,appreciate that
    Quote Originally Posted by nytech28 View Post
    Just the nut so the brass 45 is still there? It's better than just cutting through the hose.
    Aug 2014
    I decided to go with c02 tank to blowout condensor coils due to more pressure, I did lookup the adaptor I would need to avoid using a regulator on my c01l2 tank, similar to the nitrogen tank I was looking.I will attach the adaptor information below ,I would like to know if any one has this adaptor ,would appreciate it.
    That's stupider than the N2 tank. A unregulated CO2 tank is an almost endless supply of whoopazz.
    I think it's uniweld a regulator that comes with the CO2 adapter too
