Results 1 to 13 of 14
    May 2019
    SEER 38 units - worth it?
    Hello
    there are already some SEER 38 mini split units out there. I wonder how this value is being achieved? Can only be higher compression ratio and higher temperatures they work with, to my understanding. Do you believe these units will last long compared to standard 19 SEER inverters? By the formula I remember the electricity usage should on average be around only the half of a SEER 19 unit, is that correct?
    Did someone of you already install any of these "hyper" units and what are the potential caveats here? I would guess it will be more prone to leaks if there is much higher working pressure.
    Any comments? Thx
    Higher compression ratio would get you lower SEER as the compressor would be working harder, and draw more wattage.
    Mar 2018
    Kansas Flatlands
    I was understanding that all multistage, inverter equipment is able to achieve such high SEER is the ratings are taken / mixed with electric consumption / capacity in the lower stages. I E some of the ratings are taken at 72 degrees outdoor, 78 degree outdoor etc. Which is why commercial equipment is rated with EER at 95 degrees. Those who spec that equipment know how to do math and are not manipulated. How's it gonna run when it's hot. Please correct me if I'm wrong.
    The advantage of the inverter is you can size to the heating load and have the heat pump do all the heating with no backup. The lesser cooling load is just runnin the thing at a lesser speed. As far as how long will any equipment built today last? I don't own a crystal ball, but my best guess is not as long as the stuff you're replacing did.
    May 2019
    they seem to have two stage compressors, so while the combined compression ratio is higher, there is no higher-per-compressor ratio, to my understanding.
    Quote Originally Posted by sepuku View Post
    Still won't have a high compression ratio to get higher SEER. Whether using 1, 2, or more compressors.
    Lower compression ratio uses less electric.
    First stage will have a very low compression ratio, and second stage will be about normal, to a little less then normal As in close to 3 to 1
    Madison, WI/Cape Coral, FL
    Increasing the size of the coils verses the capacity has a major effect on efficiency. Varying the displacement of the compressor to maintain full motor load effects the efficiency. Pressure drop of the refrigerant passing through the refrigerant piping also effects efficiency.
    All of this increases the investment and complexity, which makes pay longer and maintaining more expensive.
    There are few tricks that are unique but "no free ride".
    Interesting.
    Regards Teddy Bear
    Here is good explanation of SEER
    https://asm-air.com/airconditioning/...d-seer-rating/
    Atlanta GA area
    Dirty little secret...
    The higher the SEER (or EER)...
    The more perfect (and I mean exactly perfect) the installation must be.
    Lets carry this a step farther...
    Why put a 30-something SEER AC into a house that has single pane windows, poor insulation, and serious infiltration issues???
    I seriously doubt the 30-something SEER would help in that house!
    GA-HVAC-Tech
    Jun 2019
    High SEER Value brings so many benefits not only financially but also environmentally. As @ga-hvac-tech said, you should be aiming for better SEER value. Of course, the initial cost will be high but later on your monthly electric dues will be low because of better efficiency.
    Jan 2010
    Once it's out of warranty all saving goes down hill quickly.
    Lowering the compression ratio is where the energy saving is.
    Larger condensing coil is how this is achieved or changing the type of coil.
    Atlanta GA area
    We sell AlliedAir (Lennox clone)... and ThermalZone (Rheem clone)...
    The former (AlliedAir) just started shipping outside units with aluminum tube coils...
    The price is a tad less than the old copper tube/aluminum fin coils...
    And they are less weight to move around!
    Lets hope this works out... as I am all for the upgrade!
    BTW: All aluminum indoor coils came last fall...
    GA-HVAC-Tech
    Nov 2008
    Piney Flats, Tn.
    Just put in a Rheem gas pack and it had micro channel coils for outdoor and indoor.
    Jun 2019
    So how is the high SEER achieved?
    Atlanta GA area
    Quote Originally Posted by gustavhorna View Post
    This is extremely simplified...
    Larger coils and smaller compressor...
    Having said that... this is only the tip of the iceberg...
    Which, BTW, is part of the reason the price of HVAC is going up....
    GA-HVAC-Tech
