Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Dec 2014
    Is nitrogen always necessary?
    Hi guys, just wondering if nitrogen is always necessary during brazing of small hermetic compressors?
    One of my refrigerated machines blew a compressor yesterday. I had a small compressor (also R134a) replaced on a commercial fridge last year and the tech said that there was no need to run nitrogen but having done some reading on here I'm wondering if it is best practice to run nitrogen even on small systems?
    Cheers,
    Adam
    kansas
    It’s always best practice although I suspect lest than 50% actually do. Doesn’t make it right a lot of times filter driers and luck is all that stands in the way of metering device failure
    Aug 2013
    Templeton MA
    I think sometimes trouble arises when the brazer is inexperienced and takes far too long on a joint building up excessive oxidation scale. Fast in fast out, with hot flame with oxy acetylene is best. That being said we always use nitrogen as we build and repair small cap tube systems, but I have seen mistakes made with no consequence.
    Dec 2009
    maroon lazyboy
    134a Cap tubes get plugged by cooked POE oil more than anything.
    Southold, NY
    By the book yes.
    Im more concerned with a good drier being installed!
    Southeastern Pa
    Since you are the equipment owner, you should be posting in the AOP Commercial Forum.
    This forum is for technicians' posts.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jan 2010
    Also depends on if the equipment your welding is still out gasing.
    May 2014
    Bay Area California
    The color of that label indicates the compressor has been running too hot. Unless that's the original color; but I don't remember ever seeing a new label that color.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Mar 2013
    Treasure coast, FL
    Quote Originally Posted by BBeerme View Post
    It looks like it was just yellow to begin with, the print on it looks to be in good shape.
    Sent from my Moto Z (2) using Tapatalk
    Dec 2009
    maroon lazyboy
    Im with Dr. BB, shes been cookin
    May 2019
    Kingston ma
    Nitrogen is always used when brazing any kind of copper piping it helps with the black crap that you get when brazing that forms on the piping
    Dec 2014
    I checked the temperature of the top of the compressor just after it started making nasty noises and it was around 85c (185F). The sticker was originally yellow/Orange though as you can see.
    May 2014
    Bay Area California
    If that was a scroll compressor, then a case could be made that it was acceptable.
    Being a recip, the dome should be only slightly above the suction temp.
    You have a serious problem with that compressor.
    Need to tell both the customer and your employer there is a problem.
    I handle things like this with an email, from my personal account, that way I have a record to defend my position that I told you so.
    Quote Originally Posted by Adammac View Post
  14. Likes lions_lair liked this post
