Results 1 to 7 of 7
    May 2019
    Hmm Outside AC Unit question
    I have a TRANE XB 10 Model # 2TWB0030A1000AB, Serial# 32540AT4F that is a 2.5T Split System Heat Pump. The compressor went out on it, which was verified by an AC technician. He told me I needed to replace the entire system outside unit and inside unit. It uses R-22 REFRIGERANT. Asked about only replacing the compressor was told hard to find since this unit was manufactured on 06/2003. The new system he quoted me is $.
    My question is: Can I just replace the outside unit as long as its from TRANE and is a 2.5T unit? I did find a compressor but after buying the part and installation I am at over $. Seems like I should be able to only replace the outside unit.
    Thanks,
    Greg
    Jul 2018
    Wisconsin
    He will likely be unable to find a whole r22 outdoor unit. I would think he would be able to find the compressor.
    Jul 2018
    Wisconsin
    Probably not the smartest idea to spend thousands on reparing a 16yr old unit.
    Southold, NY
    Your contractor is full of it. Replacements are available but I wouldn’t recommend them.
    Find a contractor you can trust
  5. Likes kangaroogod liked this post
  6. #5
    Mar 2015
    Hamersville, Ohio
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
  7. #6
    Moved to AOP.
  8. #7
    Nov 2008
    Piney Flats, Tn.
    The new refrigerant is R-410a and operates at 50 - 75% higher pressures. Your unit is a 2003 model and may not be rated to operate at those high of pressures therefor a leak is very very highly likely. So yea you need a new indoor and outdoor unit that is a matched system to get the efficiency it was designed to deliver.
