    Aug 2012
    Transit label still on unit
    Recently I purchased a commercial building with four package units like this one behind it. One unit still has this transit label on it and has probably been running that way for two or three years.
    Am I correct in assuming that this opening provides combustion air to the unit? If so, could harm be done to the unit running it like this? Is it capable of heating at all?Name:  combustion hood.jpg
    Dec 2014
    Well that needs attention. Also, the gas piping is blocking the access doors.
    I'd have a reputable tech come in and check out everything. With work like we seeing here, there's a lot else that may be wrong.
    Sent from my SM-G950U using Tapatalk
    Southold, NY
    Love the accessibility.
    So much for 3’. Where’s the safety rails?
    Jun 2014
    Dover, DE
    Nothing about that is done right.
    Gas pipe needs redone.
    Hoods are missing.
    Sticker blocking combustion air.
    I’m gonna bet it was never commissioned.
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    Local 486
    Southeastern Pa
    A complete inspection and a configuration correction for safe and easy access are in order, as mentioned.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
