Results 1 to 8 of 8
Thread: Correct tonnage
    May 2019
    Correct tonnage
    Hey guys I have a two part question here, first is this model number R2A360GKR2 a 5ton unit? I'm pretty sure it's a carrier unit since any name placards are missing. Secondly I shouldn't have a problem taking a compressor from a straight cool and installing it in a heat pump would I?
    Quote Originally Posted by Gabriel24 View Post
    This is an ICP unit (now owned by Carrier), and it is 5 ton (60).
    A compressor is a compressor, no matter if it is in a Heat pump or AC condenser. The question is, is the BTUH size and Refrigerant type, compatible for the system you are installing it in?
    Nov 2011
    Quote Originally Posted by rundawg View Post
    R2A360GKR2
    I was bettin' on 36...
    Dec 2009
    maroon lazyboy
    The heat pump compressor needs to be designed for very high compression ratios in heating mode, basically it’s a low temp system with as low as -10° SST and 110° SCT. Keeping compressors cool in those conditions can be a problem.
    Quote Originally Posted by knave View Post
    You are correct, but point I am making is, many manufacturers use the same compressor in their straight AC condensers and Heatpumps units of the same model line.
    Dec 2009
    maroon lazyboy
    That is fascinating, I never would have guessed that.
    Dec 2009
    maroon lazyboy
    That explains a few things, 😀
    Jan 2010
    Sea to Sky
    It is a 13 seer, 5 ton....hence 360
    Quote Originally Posted by Saturatedpsi View Post
    R2A360GKR2
    Sent from my SM-G965W using Tapatalk
