Results 1 to 6 of 6
    May 2009
    SC
    bunch of pictures 3
    This is a temp chiller setup. Two way valve in the AHU, when it closes it trips out the chiller on low flow (of course). This was the solution.
    Name:  2016-03-15 08.03.34_preview.jpeg
    I'll complain to people about things being hard to get to but this one I brought to the GC. If you look closely you can see the VAV I need to work on behind those pipes that all block a hatch in a hard ceiling.
    Name:  2016-05-05 10.37.46_preview.jpeg
    I'ts a carolina thing.
    Name:  2016-05-15 11.33.23-1_preview.jpeg
    Someone yanked some wires somewhere.
    Name:  2016-06-14 09.17.46_preview.jpeg
    Residential. 3rd try got it thankfully.
    Name:  2016-06-27 18.47.23_preview.jpeg
Size:  30.4 KBName:  2016-06-27 18.54.55_preview.jpeg
    We got no OSHA in residential work.
    Name:  2016-06-27 18.56.08_preview.jpeg
    Scott Jalbert, WebCTRL ninja, Naiagara AX and Smartstruxure newb, SiteScan Retired
    The master has failed more times than the beginner has even tried
    Nov 2011
    East Side
    On temporary chilled water systems, rental chillers, etc. it's very common to have a manual bypass to balance the flow....especially with rental chillers where the pump packs have way more flow than the system needs.
    Jun 2019
    Peoria, IL
    I see blocked VAVs like that way to often. HATE IT!
    Mar 2018
    Maryland
    So that air handler in the crawl. Im looking but I dont see a return duct? Did I miss it or are they pulling from the crawl!!!!
    Jan 2013
    Central Arkansas
    was the autologic a SEMCO unit? If it was new some QC person pulled the wires after testing, I use to work in one of the plants in electrical, we hated when they did that then we got blamed when the unit wouldn't run.
    May 2009
    SC
    Quote Originally Posted by Pres1227 View Post
    It's there, just a bad angle. Big flex that goes around the corner.
    Quote Originally Posted by rkevins View Post
    No, this was our panel. Think there was another panel right next to it so the wire was easy to pull. But hey the wire didn't come out of the connector and nothing got damaged.
