Results 1 to 16 of 16
Thread: Put 'em in series just like superchargers.
    Jul 2012
    This is why you hire a professional.
    Indeed, each one blows its ever-hotter air into the next one.
    I thought the picture would be appreciated here.
    Aug 2009
    Beatrice, NE
    Yeah, but it doesn't look like they bolted them down so if it gets to hot it can just move. If they are heat pumps do you suppose they would have defrost issues?
    Automatic head pressure control.
    "Right" is not the same as "Wise".
    Jan 2010
    Sea to Sky
    Quad Turbo.....that last fan must really get moving.
    Sent from my SM-G965W using Tapatalk
    May 2014
    Bay Area California
    Photo too edited and cropped to know for sure what is going on.
    Maybe some re-roofing going on?
    I do a triple evac with nitro to remove non condensables.
    Jul 2012
    Some roofing repair was being done on the strip-office building and there was a dispute about the roof which had nothing to do with the units, which were undisturbed and are in use as-placed. Not allowed to show anything about the roofing because of the dispute, only the new condensers -everything up there was new because they are renovating the building. -the roof is 5-6 years old and had some repair work going on.
    I was told the condensers vibrate the roof and make a rumbling/humming noise if screwed down. But I don't know anything about that or enough about HVAC to comment except to post the image of the strange arrangement.
    May 2014
    Bay Area California
    Hah, nailed it.
    How did I guess that?
    May 2014
    Bay Area California
    I mean, not like I have ever seen anything like that before.
    May 2015
    Doesn't work like a Cascade system?
    May 2014
    Bay Area California
    Pretty sure a good salesman could sell that to property management.
    Each unit makes more heat to help the next one get hotter to make it easier to transfer the heat to the outdoors.
    Quote Originally Posted by joeysmith View Post
    Feb 2018
    Bay Area, Ca
    Quote Originally Posted by BBeerme View Post
    Heat recovery?
    Sent from my SM-G955U using Tapatalk
    Aug 2009
    Beatrice, NE
    If you put them in a square at just the right angle all facing in could you generate a small tornado with them do you suppose?
  13. Likes Core_d liked this post.
  14. #13
    Sep 2009
    Los Angeles
    A large, prominent piping company in LA/Orange that has well deserved reputation for high end quality work didn't have any freon peons on their payroll. We did all their HVAC maintenance, on their offices, shops, clean rooms and we also performed their start ups & repairs on projects. Was starting up three mini splits down in a well & I must say the line set piping was beautiful... except they were close together & the 1st condenser air discharged into the 2nd & it's into the 3rd. The foreman did NOT want to hear his beautiful work had to be redone. At least the line sets only had a standing nitrogen pressure test.
    What I don't understand about this is I don't ever recall hearing a loud, vibrating mini split condenser & have only seen UCLA spec rubber mounts on their feet for the dorms.
    "The United States is a distillation of the human spirit of exploration."
    Elon Musk
  15. #14
    Dec 2012
    columbus, OH
    Do they work? Bet it goes like 16seer, 13seer, 10seer, 7seer, high head trip...
  16. #15
    Dec 2012
    columbus, OH
    Quote Originally Posted by Core_d View Post
    Oh its only 4... you should be good.
  17. #16
    May 2014
    Bay Area California
    They need to get the high speed auxiliary fan option. Well, three of them. They mount perpendicular to the existing air flow. And blow the heat away before it can get to the next unit.
