Results 1 to 9 of 9
Thread: Salad bar
    May 2019
    Salad bar
    Hey I'm brand new here and somewhat new to the industry as well. I work in a hospital maintenance department where I get work orders from the boiler room, chiller plant, to the medical and kitchen refrigeration equipment. That's my intro. Now, my present problem is a salad bar not holding temp below about 40.
    The Tecumseh condensing unit was replaced (by an outside contractor) about 2 months ago. The problem first presented about a month ago. I found a leak at the suction service valve so I replaced, pressurized with 100psi nitrogen, leak tested (no bubbles), vacuumed and and recharged 404a. No record of how much to charge so I calculated 18 ounces being 80% of the receiver's labelled capacity of 37.4 cubic inches. The head pressure is 217! Low side is 18, the condenser fan is working, coil clean. Food is actually temping 37 which is ok but these pressures!?
    Jan 2010
    It's a cold wall type case ?
    Southold, NY
    Pressures without temperatures are worthless.
    Crazy Question...…...X-Valve or Cap Tube metering device?
    May 2019
    Yes
    May 2019
    I'm sorry about the confusion, please bear with me as I learn how to use the forum.
    It is a txv (which is icing up),superheat 84 (room temp 70), it is a cold wall type salad bar. Thanks.
    Southold, NY
    OK
    Is there a Sight Glass after the drier?
    Is the Sight Glass Clear?
    84F SH...….Where?
    Also a salad bar is only designed to keep the salad Cool not cold. 45 - 50f is fine
    May 2019
    OK
    84F SH....Where?
    No sight glass...sh is about 10" from compressor, state requires food to be under 40.
    Southold, NY
    Quote Originally Posted by Andy Merrill View Post
    Get a Sight Glass!!!
    SH at the pump 20 - 40F
    I wouldn't adjust until the SG is installed and charge checked!
  9. Likes icemeister liked this post.
  10. #9
    May 2019
    Will do, thanks
