Results 14 to 26 of 45
    May 2014
    Bay Area California
    I really just wanted to type 'vacuum is normal', but it sounds like this guy's heart is in the right place.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Athens, Ohio
    X2 for the Bluvac. They're all excellent.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    May 2014
    Bay Area California
    Quote Originally Posted by kdean1 View Post
    Micro.
    Southold, NY
    Quote Originally Posted by sepuku View Post
    now, tell me the model of micron gauge that will work and not stop working after few months (and something that is not $1000).
    That’s like saying I want a vacuum pump for less then $300.
    Do it right. Good tools save time and money!
    May 2019
    MICRO BLUVAC MICRON GAUGE - not sold any more, eventually replaced by AccuTools BluVac+ Micro Digital Micron Gauge with Oil Sensor A10730 ?
    I Was looking time ago at YELLOW JACKET 69020 but all the negative comments made me desist from purchase. Plenty of gauges on Amazon but mostly all have comments like "stopped to work after xxx days" etc. Cannot afford $1000 on something really pro.
    Southold, NY
    Decent the micron gauges are available for a few hundred.
    May 2019
    TPI 605 or CPS VG200 would be in my budget - which one? (none is no valid answer).
    Southold, NY
    Better then guessing!
    May 2019
    lol
    May 2014
    Bay Area California
    Where do you live?
    https://accutools.com/product/%C2%B5...l-micron-gauge
    Used to be a hundred bucks.
    https://www.trutechtools.com/Accutoo...l-Micron-Gauge
    I guess sellers figured out they could charge more.
    May 2014
    Bay Area California
    Shop around, several months ago you could get them for $150.
    Quote Originally Posted by BBeerme View Post
    Where do you live?
    Nov 2018
    vacuum is not the proper way to leak test at all. the gasket could have sealed under negative pressure but wouldn't hold up to positive pressure from refrigerant or nitrogen. plus 500psi sets the flare fittings on any connections plus mini splits can run high head pressures more so than conventional split systems.
    May 2014
    Bay Area California
    Say what?
    Holding a vacuum is a supreme way to check for leaks.
    Oh. Looks like you're the new guy here.
    Suck it up, stick through the initial bashing, and you'll come out sparkling on the other side.
    Quote Originally Posted by ecw View Post
