    Jul 2002
    SE Texas
    Tempered Make-Up Air
    The kitchen exhaust hoods for our new school have been installed.
    Make & Model - Caddy Corporation PB-C-W-142.5-ND-60
    Link to spec sheet - http://www.caddycorp.com/userfiles/p...lter.Style.pdf
    Here's what it says about make-up air:
    Make-Up Air (Perimeter Down Discharge)
    Ventilator shall have 40% open stainless steel perforated
    screens for downward discharge of tempered make-up air.
    Supply volume is 80% or designed to the desired air balance.
    To you, does tempered make-up air mean heated, cooled, both or something else? Thanks.
    With your chrome heart shining in the sun, long may you run.
    Apr 2003
    Maple Grove, MN
    Heated only.
    Cooled make-up air is a fairly rare beast. If it was supposed to be cooled, it would have said so.
    Jul 2002
    SE Texas
    Okay, that's what I thought. I started another thread a while back on kitchen ventilation and that was the consensus. Hopefully, I can be there when they're balancing the system to see if the outside air is going to be a nuisance or not. Thanks for the reply.
