Did a replacement ac today and the 220 line to the dissconnect was ran in the same hole as the line set.the disconnect was mounted on top of line set low enoghr so the wire entered the back of the dissconnect with no wire showing from outside.I mounted the new dissconnect in the same location but drilled a seperate hole to keep it away from the line set,are both these done to code?
© VerticalScope Inc. All Rights Reserved.
